loose connection on power trim unit
pikerpiker
I have a 1989 marnier tiller 75 hp trim was work fine .The boat has sit for about 2 weeks and I tried to to tilt the motor and nothing . Battery is fine but no trim or tilt. I'm thinking a loose connection but where to start? And help would be greatly helpfully Thanks Chris This is a single ram unit with the trim button on the tiller backet arm and its the two wire unit blue and green wires
pikerpiker
Re: loose connection on power trim unit
Never mind guys find the problem it was the green and blue wires connection was loose on both fix the problem I like when it's that easy for a change good luck everyone
