Loose bolts
huntingdeer
87 mercruser 5.0 alpha one
Sorry about the spelling my phone keeps changing words over and over again.
Ok so I have had a on going water leak coming from the transom.it comes from the plate on the inside of the transom.so I was poking around and found the two top bolts loose.how many bolts are on the inside plate.i hope to god this fixes it lol.this boat has been trouble sense I got it.
Re: Loose bolts
Ayuh,.... Those bolts don't loosen, by themselves,...
Yer Transom is Rotten,....
huntingdeer
Re: Loose bolts
Well I drilled threw the transom a few mounts ago and it seemed to have good wood.i did a few holes and patched them up with fiberglass.the guy that owned the boat I think he thought he was a boat mechanic and was not.ive found a lot someone has messed with.
alldodge
Re: Loose bolts
In your previous thread ...on going water leak just about all was telling you have a rotten transom. Drilling a few holes and some coming up wet confirms it, pretty much. The location of where the holes were drilled can also be an issue as to finding wet wood.
huntingdeer
Re: Loose bolts
I mean I know it is probably in the stage of rotting but still has a good bit of life left(this year).i found like one place that was wet but still very stiff.im just wondering if just 2 bolts holds the plate tight or is their 2 on the bottom.
Bt Doctur
Re: Loose bolts
Think the total is 8 bolts,nuts. Coming from the plate inside means nothing. Loose rotted transom is a trickle from the bottom. A rotted transom or a very hard bottom strike can cause it. A visable trickle is either a corroded hole, bellows, shift bellow, exaust Y pipe.
