Looking for Painting advice, Hull and Topside Repair
kayrecs
Hello All -
I purchased a 1962 Lone Star and 50 HP Johnson Seahorse 50 last April and with the help of members here, special shout out to:
Bosunsmate for really helping me with getting the motor running and lots of trouble shooting! I enjoyed the boat as much as I could this summer and am getting the itch to do something now that it's not in a project state..
The floor and transom seem solid enough, and I am not looking to do a gut-out restoration as I am planning on upgrading the jeep to a pickup and the runabout for a pontoon as the wife and I are planning to start our family. As is, it starts, runs and floats, taking on almost no water except once in some heavy waves when it was seeping in where the cap and hull meet, a little sealing can fix that.
To start - Part of the reason I fell in love with this boat was the color, which I was thinking of just refreshing on the topside and trying to fix up some of the scratches, dings and drill holes. Then... I got stuck on this forum and youtube and am now considering repairing the hull and painting as well.
In summary I am looking for tips on repairing/filling the chips and advice on techniques and paint manufactures to get the job done. Also can I paint the boat on the trailer? I am trying to avoid removing the motor as I do not have a lift or desire to do so.. Think Maaco for the type of paint job I am trying to achieve lol.
Thanks for the input!
Ben
Woodonglass
Honorary Supreme Mariner
I have a 61' Lonestar "Blue Flamingo" I painted her with a custom mix using Tractor Paint with Hardener. It worked Great. You might consider doing the same... Paint Your Boat with Tractor Paint...Say What!!!
http://forums.iboats.com/forum/boat-...40#post5229140
sphelps
I did the same as WOG on this "ol gal " ! Has held up pretty well so far ... And scratches are super easy to touch up .. ;)
kayrecs
Woah! Sold. Thanks for the input and laughs guys.
Would you recommend spraying or just rolling and tipping? I have a smaller Husky 3 Gallon compressor and am willing to buy a cheap spray gun, but it almost seems better to roll it out..
Would filling those holes and scratches with the 3M Marine filler be ok? I've read nothing but great reviews, but those can be bought.
Would it be ok / advisable to to paint the inside of the boat as well? I was thinking it'd be cool to do a truck bed liner of sorts, to be able to hose it out per se.
sphelps ​Great looking boat btw! Lots of inspiration! I really like the white hull and What was the color you used on the topside?
kayrecs
No Title
Here are a few more photos to keep things going. I've backed the trailer up in the garage and got the boat ready to get this started. I got excited and started scuffing it up a little with some 60 grit I had laying around. These are some of the topside repairs I've got in store..
Woodonglass
Looks like you've got quite a bit of "Spider Cracking"' going on. To fix those correctly for the long term, you'll need to get either a v-bit for your drill or dremel tool and grind each and every one of them down to the glass from one end to the other. This can be a long and tedious process but must be done. It's either that or grind all teh gelcoat off and start over. Once you get them and all the other gouges ground out and feathered, you should fill them with a premium filler such as 3M's Premium fiberglass filler. I'd recommend thinning it with a bit of acetone to make it a bit more creamy and easier to work with. Then the sanding and fairing begins. Then a couple of coats of a primer and then you can paint her. sphelps and I both custom mixed our own paint. Fairly easy to do. Started with White Rustoleum and them mixed Rustoleum Blue and some Green until we got the shade we were looking for. We both sprayed ours but you can get Great results using the roll n' Roll method too!!! It's all in the link I provided in Post #3
sphelps
That would be SP Green .. :D
Like Woody said You can mix it till you get the color you want .. I bought the vinyl for the seats then tried to match that ..
Gloss white , John Deere green , and Ford blue ..
Nice Lone Star btw !!
gm280
The only think I would interject into this conversation is, if you do go the self mixed route, make sure you know the absolute recipe if mixing. Because down the road you may want to either duplicate that color, or mix up a batch for touch ups. So self mixing has to be precise and know the exact amounts of each color mixed in. BTW Sam, I have seen your boat before, but it stand to say again, really nice job there. :thumb:
Woodonglass
Mixing the paint is not all that hard. I can be a bit tedious and time consuming but you will eventually get the shade you want.
A Pad of paper and a pencil and some measuring spoons from the dollar store is about all you need. Start with small amounts. A teaspoon of white, 1/2 teaspoon of blue , 1/4 teaspoon of green. Mix. check the shade and see if it's what your want brush it on white paper and use a hair dryer to dry it. Put the mix ratio next to the color. Change the next ratios according to what you think you need to do to change the color in the direction you need it to go and put it on the paper and dry it and record it. Once you have the color you want you'll know the correct ratio and then you can increase it incrementally to get it into a larger volume in order to spray or roll it.
DeepBlue2010
Getting the shade you want is only half the battle and you can accomplish this even by luck. Start with well rounded ratios like 1 part to half to third but then you add a little bit of this, a hair of that a dash of this and a hint of that and all of the sudden you have no ratios to duplicate. Even if you mix large enough quantities for the job, you might not be able to duplicate if you need to touch up few months down the road.
If you don't have a eagle eye and you don't do this for living and you still want to mix your own color, the way I do it might be helpful to you
I got myself a sensitive jeweler scale 500g with 0.01 gram precision (0.01g = 0.0003527396oz) I weight the individual containers that I will be mixing from and with each one I also weight the tool I will be using for mixing (a syringe usually one for each color)
After I am done mixing, I put back each syringe on top of it associated container and weight again (this will account for the amount of paint left in the syringe)
Subtract after from before and you got your weight for every color. Scaling this up is just a matter of simple math and you can replicate your color any time you need it. Anything else is just a guessing game at least for me.
kayrecs
Thanks for help guys! I like the idea of mixing colors and letting them dry to see what it looks like, keeping track of the recipes. I have a digital scale, but will just work with the spoons. Couldn't I just pour out a little paint in a small jar once I have my final shade batch mixed before adding the hardener?
I was thinking I am going to roll the bottom side and try my luck shooting the top with a cheap HVLP gun. Is the 3M fiberglass filler the same as the marine product? Hoping to get some more sanding done today. I started marking all the holes and blemishes with a sharpie so I can go to town with the filler.
sphelps
Yep 3m premium marine filler .. Mix up more paint than you will need so you will have some for touch up later on ... Only add the hardener to the amount you are spraying or rolling ..Once the hardener is added you have roughly 8 hrs to use it or loose it ..
Woodonglass
Yup, the "Spoon" method is really simple and very accurate. You are Spot ON about mixing some extra and storing in for "Touch Ups" later on. I have a Whole Quart of my custom color in a Sealed Quart Can on the shelf that I can pull from at any time for those pesky chips and scratches. A PreVal sprayer makes Quick Work on those!!!! I figure it'll take about 10 years to run out of paint doing touch ups etc. Heck I could probably to a Full Recoat of the Top cap with that Quart!!!!:D But I'm confident that my "Recipe" is "On the Money" and I could duplicate the mix with no issues and not have to use scales to get so specific. I doubt that any minute variances that I might have in my measurements would be noticeable to the human eye and I'm also aware that it's never gunna be perfect anyway cuz mother nature is always gunna "Do her Thang" and make it impossible to match the paint perfectly anywhooo!!! We can only do the best we can do and call it good!!!! ;):eagerness:
3M Premium Marine filler is what I used and then I started making my own. If you use the 3M stuff I recommend thinning it with a bit of Acetone to make it a bit more creamy and more spreadable. Also cut back a bit on the hardener to give you a bit more working time. It sands like a dream. You can make your own using polyresin, Glass Bubbles (Q Cells) and Cabosil then add hardener. Basically the same stuff as the 3M. Easier to control the consistency when you make your own. A bit cheaper too.
gm280
Well I can easily see colors, even though I am color blind to certain colors, but shading is a whole other issue. That is one reason I would never be a quality auto painter. I could easily paint the entire vehicle, but never do very well with patch and spot work. I have a limitation to subtle shadings. I guess the rods or cones in my eyes are not as great as my wife's. However, I can paint colors and do a pretty good job as well as long as I am not trying to match up shades. :facepalm:
DeepBlue2010
Same here. When it comes to color shades, I prefer to leave to algorithmic methods and computers.
Woodonglass
Yeah I watched an episode of "Bitchin Rides" once where they matched a $100,000 hot rod paint job of pearlized white paint. It only took their master painter about 15 times to get it PERFECT. They worried for a week that the owner was gunna notice it. When they got it out in the sunlight and got it under scrutiny no one could tell it from the original. I thought WOW that's some kinda picky wicky paintmatching!!!! WAYYYY to picky for me but then again, I don't own anything worth that kind of money so I guess if I did I might be that kinda picky!!!!!:lol: That's also prolly why I use Rustoleum and Harbor FREIGHT!!!!! C.O.B!!!!!
zool
Paint matching is rarely, if ever perfect...it doesn't have to be as long as the illusion is created.....most patches are blended over wide areas, and terminate just beyond a panel break, like a car door seam or and angle change, like a hull chine where it would even look slightly different, even with the same paint batch mix...
The color cards make it close, but the painter makes it work.
kayrecs
Haha wow - I'm on the same page as Woodonglass
I'm not trying to get scientific with this paint job lol. I'll also be using cheap tools and paint in my garage with spare time lol.
I've started to fill some of the holes on the topside and thinking over the job ahead. I was looking at cheap HVLP guns at HF, Northern Tool and HD and began to realize my compressor may not be up to the task at 3 Gal..
I may end up rolling and brushing everything. Is there an anything in a spray can I could use for the topside, or would it just look like bad?
gm280
Before you abandon the spraying effort, what is your 3HP compressor specs? I don't see how that won't work spraying with a HVLP gun setup. HVLP guns really don't take a lot of CFMs to work properly. Most HVLP guns take about 40PSI at the inlet of the gun and that translates to about 10PSI at the spray tip. So a lot of CFMs really isn't needed to get quality paint finishes. JMHO!
