redneck joe
- Mar 18, 2009
- 16,195
The power output per displacement is higher, the motor is 1/2 as complex as a 4-stroke,, the 2 stroke is seriously lighter than an equivalent powered 4-stroke and they pretty much last forever with minimal maintenance.Why do you prefer the 2 stroke over the 4 stroke?
So will property owners with water front property. Wonder if any law suits have been issued to "wake boat" owners/operators for tearing up folks boats, piers, docks, and water front bulkheads!!!!!!A stern drive is not usually a good choice or a ski boat. They are 1100 pounds or so, causing the boat to put out a larger wake.
An OB will be less than half that weight, have plenty of power and produce a smaller wake. Anyone who cuts across the wake on skis will appreciate the smaller wake.
I get more than 35 mph in my 1990 prostar but yes I could pull a dead in the water pontoon at 35 mph. Mastercrafts of that era are specific task boats the passenger seats faces backwards made to watch a skier not cruise.a dedicated ski boat requires deep water as they draw a bit for the rudder and prop. remember that when you are looking at older mastercrafts or ski nautiques. They also are extremely specific to skiing. they will pull up to a dozen skiers right up to 35mph..... no more. boats like the ProStar or MariStar would be good boats if you find a well cared for one as your budget has you looking at 25-30 year old examples of well-cared for ski boats.
Caravelle eliminated all wood from their boats from 2007 - up, so that is a major plus.Ok, so I've found a 2007 Caravelle 217 LS with the Mercruiser 5.0 MPI and a 2004 Chaparral 204 SSI with the same engine. Looks like both boats weigh about the same. The Caravelle is much cleaner and has carpet but the Chaparral closer by about 8 hours.
