looking for gears
todd776
I have a 1962 johnson seahorse 10hp QD 23A......I need new lower gears for it.....it keeps kicking out of gear so I looked and the drive gears are stripped out.....I cant seem to find what i need... any help would be appreciated....thanks
F_R
Re: looking for gears
todd, by "stripped out", do you mean the gear teeth are stripped? If so, better check the bushing in the gearcase, right above the pinion gear. They wear and that lets the pinion move to one side, causing catastrophic gear damage. Pretty common in the 10hp motors 1958 and newer.
What I'm saying is if that is what you have, don't waste your time on replacement gears. They will just strip again. The bushing is cast in and not replaceable.
kfa4303
Banned
H i todd. I used to have a '61 QD-22 myself. In addition to the gears, you may also want to check your clutch dog. The old 10 hp were prone to wearing them out. In addition to the link Haffiman posted, check ebay and/or place a WTB ad aomci.org. Here are some handy links to keep your motor on the water.
http://www.leeroysramblings.com/johnson_QD.htm
http://forums.iboats.com/showthread.php?t=277190&highlight=lower+unit+seal+kit+installation
http://www.marineengine.com/parts/v...ntage-evinrude-johnson/378823/37882300001.htm
