hello all, first off i know its in the wrong forum but i am looking for any ideas.
I have a honda 115 efi that starts, idles smooth but when i leave the pontoon it will respond well for 5 mins then it will start missing and struggles to maintain revs, at this stage i have to throttle back and limp home. back at the pontoon the engine will run rough, even in neutral.
I have cleaned or changed everything in the fuel system from tank upto the injector rai including the vapor sep components. I looked at the fuel pump diaphram,ok ,tank vent,ok . I am beginning to think that its a heat related problem., maybe ht leads/coil or maybe headgasket. The engine will idle at the pontoon all day but will not run after 5 mins use in open water????
Any help or suggestions very welcome because its doing my head in!
