Does anyone know if a 59 50 hp driveshaft has an extension on it or do I need a short driveshaft to convert it to a short shaft? Also can a long shifter rod be modified? I read somewhere that the water tube can be cut 5 inches and be used.
You will need a new shaft. no doubt about that at all.
tube can be cut, and there should be an extension for the shift rod. 99% of the time there is. I have seen only one motor than had a longer shift rod.
