Loctite PL - what kind to use?
NatedoggAZ
I bought 2 different kinds of Loctite PL today to possibly work as a sealant/glue if needed.
I was surprised they had the Marine type at Home Depot:
https://www.homedepot.com/p/Loctite-PL-Marine-10-fl-oz-Fast-Cure-Adhesive-Sealant-2016891/206156418
They also had the regular Premium kind:
https://www.homedepot.com/p/Loctite...thane-Construction-Adhesive-1390595/202020473
I bought them both - can take one back if I need to...
Am I spending 3x as much on the Marine one for nothing though?
Thanks!
ND
froggy1150
Ensign
The regular one is for bonding things like wood to wood. The marine is more of a sealant adhesive. I would use that for things submerged and the other for making stringers
NatedoggAZ
Coolio - I'll take the marine one back then - thanks!
It will be used to bond stringers if necessary - and the edge of the decking to the hull if necessary, around the edges.
ND..
dingbat
The marine is water proof. The regular is water resistant....big difference.
I personally would not use anything water resistant on a boat.
Woodonglass
I recommend taking both back and NOT using PL at all. Peanut Butter (Thickened Resin) is cheaper and better for all boat work. But...I AM just and Dumb Old Okie!!!!:D
