Re: Loction on bilge pump on 1800 xr
My 1995 1800XR has the bilge pump in the bilge (directly below where the outboard is mounted). Your boat is most likely laid out like mine, in that it has 2 jumpseats on either side of the back. Between those 2 seats is the splashwell console. Under that is where your bilge will be...and the bilge pump will be in the bottom of that bilge. The bilge is essentially the lowest place on the boat...where your plug goes in on the outside...otherside of that hole is the bilge. On the side of your boat is probably a through-hole that the water is pumped out of.
