SgtMaj
Thread starter- Joined
- Nov 19, 2007
- 1,997
Well, since I have everything I need (except time) to finish the transom, the next thing I'll finish is the deck. To do that, I'll need to install a couple of things under the deck first. Those being the gas tank, and the livewell.
I'm a little clueless on both, but much more clueless on the livewell. I do not quite understand how normal livewells work. I know you flip a switch and the livewell fills with water, which means there is an electric pump wired through a switch, with a through-hull fitting to suck the water in. Now I assume that same pump keeps operating to replenish the water with fresh water, thus bringing in more oxygenated water. But how does the old water exit the livewell? If there were just a second pump also wired in through the same switch, then no matter which pump pumped more water, you'd end up with a problem. Either an overflowing livewell, or an empty one. Can someone help me out here and explain how to plumb it all in right?
I know it's been said many times here that it's easier/better to just use a portable livewell, but I've always wanted a built-in livewell and by golly that's exactly what I'm going to do one way or another. Especially since the deck is already torn up.
I found a company that will make me a custom-fit livewell tank to fit the spot I've got (which isn't very big, so having it custom fit will help maximize the space). Unfortuneately their tank won't come with all the fittings, which is why I'm here asking about it.
