Live well questions.....
Hi...I have a 1989 Javelin F/S...It has a center live well which has the aerator and I can figure it out....but on either side are wells with plugs which I assume is for your catch. But how to you get water into the wells. There is no aerator on them. Do I have to bucket water into them then drain out with plug or am I missing something here.....Thanks in advance....
Tony T.
If possible pictures would help a lot to better understand your livewell setup and what exactly your referring to.
Tony
gm280
Without pictures it sounds like you have ONE live well and two dry storage compartments. The reason for plugs in what looks like drains, is so if water does get into those areas you can pop the plug out and allow them to drain out. But without pictures that is only a guess on my part.
