little water flow in 225 johnson...
roger777
I bought a boat with twin 94 johnson 225s the first thing I did was change impeller and housing.. It was my first time doing so.. Everything went fine although i was a little surprised to see the counter rotation impeller was installed the same direction as standard rotation but I heard that is the way it should be.. When I run the motors on muffs the cr spits out a stream about 12 feet from the boat while the other motor only spits out about 2 feet. I did not check for clogs in the line yet. I am not sure how to anyways.. If anyone can give me a heads up on what to look for.... I dont want to drop the lower unit unless i have to... I am sure I put it back together correctly because i did one at a time and compared the two as I went..
thanks
Roger
tashasdaddy
Re: little water flow in 225 johnson...
do they have the same size outlets at the tale tell. are you sure you did not pinch the grommet with the water tube?
roger777
I dont think I pinched the grommit but I might have..It was a little difficult getting it back on by myself.. One other thing I did notice today is that there is a little exaust coming out of the two holes beside the water streammm. The other motor with alot of water does not have exaust..
Thanks
