little half moon thing that keeps flywheel turning shaft
peacekeeper6
well this thing keeps breaking, is there some kind of super thing that is used to keep it from breaking?
scotiany
Re: little half moon thing that keeps flywheel turning shaft
I'm assuming you mean the flywheel key. It can break from undertorqueing the flywheel nut. It can break from ignition timing being wrong.
Scaaty
And its called a "Woodruf" key
peacekeeper6
yea woodruff key, so u say undertorqueing the flywheel which is probably what happened. how can it break from the timing being wrong? if the timing was wrong wouldnt the enigne not run?>
peacekeeper6
well i found out today that the thing was broke because it backfired.
