This is a new thread Re: the project at the following web site: 15' Flats Conversion Part 1 <br />
Hi all,<br /><br />Winger Ed zeroed right in on what I want to do. I have a Center Console from a trashed bass boat and several 'Rude control sets that should work. But I need information from you experienced builders out there on how to make strong, functional, lightweight casting decks fore and aft. <br /><br />The widest interior beam of the boat is 6' (and because it is only a 15' boat) the fore and aft casting platforms will probably be around 4' long to make room for the cockpit.<br /><br />So: <br /><br />Will 1/2" ply be ok for the platforms?<br /><br />Is it ok to use glass and resin on the top of the decks and simply saturate the bottoms and edges with resin for water protection? <br /><br />How much support will be needed to be able to walk on the casting decks given the 6' width?<br /><br />What is the smart way to make hatches for anchor, storage, etc. especially in regard to water intrusion?<br /><br />What is good for storage lockers? Coolers? Plastic tubs of some sort? Should they be foamed in? Drained?<br /><br />I know I ask a lot of questions and thank you for answering them all. Answers to the above questions will go a long way to help me figure out how to lay out and build the structure while making room for batteries, gas tanks, coolers, dry storage, livewells, etc. and still keep it all lite.<br /><br />Thanks guys.Originally posted by Winger Ed.:<br />That is one heck of a boat. At this stage of the game, if you're working towards making it the ultimate fishing machine, you might also consider ripping out all the interior.<br /><br />That would open up more options as far as making a center console driver's station and casting platforms both 'fore & aft.<br /><br />Going from there- you could make it lighter and stronger than it was the day it left the factory, and it'd be light enough to run on wet grass.
