Lightened boat, same speed?
LAWRENCE Owen
So glad to be a new member of this forum. My recently purchased 1977 Aquasport 222 has a "marineized" 350 sbc and I was told is a 300 hp. Good luck! With a dual-control full tower it would run 18 mph @ 3,800 rpms. To gain more speed I removed the tower to get the weight down. Now it runs the same18 mph at 3,800 rpms.
Maybe a prop or a tranny issue? I love the boat and can't afford a re-power. Idles smooth and timing is spot on, has new points, plugs, wires, Holley, DUI distributor, etc. Thanks for your input. Larry
welcome aboard
you have a motor or prop issue
the motor should be at 5000 RPM at full throttle
what prop do you have?
what gear ratio drive do you have?
you should have a 1.5:1 drive or about there, and about a 19 or 21 pitch prop.
when was the last time you did a compression test?
when was the last time you did a tune up?
When was the last time you check fuel pressure from your pump?
Grub54891
Being that vintage, it could be water logged also. Find the specs for the boat, and trailer and weigh it.
LAWRENCE Owen
Thanks. Boat is restored and dry. Compression is 175 across the board, tuned up with all new tune up stuff including electric fuel pump; 4-7 psi. Engine is >< 4800 at full power. Timing is 10-degrees BTDC @ 600 rpms/ 35-degrees @ 4000 rpms. You can see why I'm stumped.
LAWRENCE Owen
I will check the prop specs (have a great prop shop close by) and the gear ratio.
if your compression is 175, check your gauge. your only going to see about 150-160 psi max on a marine SBC and that is at 9.5:1 compression.
jimmbo
You say the carb is a Holley. 2 bbl or 4bbl, which model? Does the throttle linkage/cable permit WOT? If a 4bbl are the secondaries free to open? Any restriction in the exhaust? Since it was a Marinized engine... any idea if the conversion included putting a marine cam? What intake manifold is on it, GM or aftermarket?
so the motor does go to 4800 RPM at WOT under load? what is your speed at WOT? GPS speed, not the crappy speedometer speed
if so, what is the problem? you give a 18mph at 3800 RPM. it was assumed that is all it had. if you truly hit 4800 at WOT, that is simply an arbitrary point in the middle of the prop curve. if that is the case, hull shape, prop pitch RPM of engine, prop slip and gear ratio all come into play, however weight doesn't.
please clarify. most likely you removed everything for nothing.
LAWRENCE Owen
I'll get the numbers and the info you suggest, and see what the speed is at 4800. Should have done this. Carb is new Holley 650 marine 4bbl atop what looks to be the stock GM intake and the linkage is correct. Secondaries are opening; too easily in my estimation -- when I accelerate beyond the 3800 cruising rpms. Exhaust is straight thru, raw salt water cooled.
Cruise is generally about 3000-3400 RPM, however usually determined with a fuel flow meter.
above 3800 RPM is normal for the secondaries to open on an SBC, your loading your motor and demanding more power you can change the springs in the vac chamber if needed. what are the holley carb numbers, this will determine what the setup should have been.
jimmbo
Holley 650 Spreadbore 0-80552. It's the 4bbl I have. A 350 turning 5000 rpm is not going to use all of that carb, the secondaires when open 50 percent, will be more than enough. It is jetted a bit rich on the secondary side
Click image for larger version  Name:	large0-80552.jpg Views:	1 Size:	155.9 KB ID:	10691478
LAWRENCE Owen
Yes, jimmbo, this Holley 0-80552 is the carb. I will get the prop specs asap. My logic is if the current prop is pushing the boat only 18 mph, a larger, pitch-correct prop will push the boat faster at 3800 rpms. Is my thinking correct?
no, going to a bigger prop will most likely lug the motor and kill it. you prop for WOT
your 80552 holley is a 4175, 650 CFM, #61 primary jets, #50 power vavle and a 0.04 squirter.
the squirter is a bit large for the 5.7 (most are in the 0.028-0.031 range) and as Jim stated, it will run a bit rich on the secondaries.
you still have not posted what your WOT RPM and speed is (with a qualified tach and a GPS speed)
WesNewell
If you can get the engine up to the same 3800rpm, then yes, you will go faster. But at wot the ehcine rpm should be within the max rpm ratings. Forget 3800 rpm and set it up properly for best engine performance. Normally, that would mean at wot with normal load, you should be somewhere close to the middle of the rpm range as a general rule.
dingbat
Well, the numbers aren't adding up
maybe, maybe not.
The inboard makes for a very stable platform but a dog when it comes to speed. I walked away from a diesel Shamrock because of the speed issue
