lifting a trailer
brownbillzoo
our trailer sitts real low to the ground we need to rasie it about 2 inches any ideals on how to do that many thanks
JB
Re: lifting a trailer
Hi, Bill.<br /><br />You could use larger diameter tires/wheels. You could put spacer blocks between the springs and axles. Or you could use a combination.<br /><br />Good luck. :)
TGattis
Spacer blocks will only work on an axle that is "overslung" meaning that the springs rest on top of the axle. If oversized tires?wheels won't interfere with the fenders thats probably the way to go. Otherwise you will have to buy an axle parts attaching kit and add square tubing of the appropriate size on the bottom of the rail and then install/weld the attaching kit.
