Lifting a 115HP OMC
estame6
1995 Rage Boston Whaler Jet Drive
When lifting this motor do I install a lifting ring under the flywheel and if so any suggestions where to get one. Many thanks,,,
estame6
Thank you, what is the correct name for this item.
I welded a U-BOLT onto a nut.----Removed flywheel nut and installed lifting device.----Or buy the proper flywheel puller and put some rope through it.----Power head and muffler are about 200 LBS.
estame6
Thanks all, checked prices, think I'll get my welder out also.
Cheers.
