Lessons in Slip Docking
Reyny
I am a first time boat owner with no prior experience. I purchased a 2006 300 I/O twin Merc engins Sea Ray in June and have taken about 30 hrs of lessons with a certified Capt. I have become pretty comfortable with docking in my slip using the following procedure learned from the lessons.
While backing in, to move the stern right and left, I use the steering wheel and port or starboard engine, one at a time.
A local experienced boater indicated it could be easier to use just the throttles and not the steering wheel for this manuver. My instructer disagrees. He feels that the throttles only docking is best for Inboard boats not I/Os. I have not tried that approach.
Any input would be greatly appreciated.
Thanks Much
Rey
firehog6305
Re: Lessons in Slip Docking
well I have a 29ft w/ twin motors i/o, I find it more easier, to use your steering wheel to back in to my slip, hope that helps ya, and welcome to iboats:)
Reyny
Thanks Firehog,
I think I will stay with what I was taught. And I am sure it is what is most comfortable.
Rey
SuperNova
I run a 28 foot with twin i/o and I agree with the wheel for backing. There is a time for using the throttles to maneuver, granted, but backing up isn't that time.
Stan
tashasdaddy
i/o thrust the water in the direction the outdrive is pointed either forward or reverse. inboards are totally different, in that there thrust is either forward or back, and rely on water pressure on the rudder to direct the boat.
eriediver
I think it's eaier to use the engines & not touch the wheel (especially if it's very windy), but that's me. Do it however you are most comftorable. Just remember if you're gonna try with just the throttles to make sure the drives are straight.
gcboat
And, as another mariner so eloquently phrases it " never approach a dock any faster then you plan on hitting it". :D
Reyny
Thanks Guys. appreciate the input.
Practice practice practice. I can see that is the way to go.
Also, many fenders will be used.
Rey
Reyny
And tashasdaddy.
that visual i/o vs. inboard clarifies my thoughts.
Thanks all
NSBCraig
I don't see how there is a rule change it up and play with it that's what boats are for right!
On inboards I've never seen anything good about having the rudders not sitting straight.
On my brothers 41' velocity I've used the wheel when heading into his really long slip and then went to straight gear changes when in between the pillars.
The biggest thing that helped me with larger boats is learning how much thrust the boat makes with a big hatteras or even my brothers boat don't just stick it in gear and try to drive it in or out shift it in and take it right back out kind of like manuvering thrusters see what the boat does and then make a correction.
Works real good for me alot of people seem to think I'm some awesome boater cause I take it easy and don't freak out around docks to the point I normally have to take the helm in other peoples boats all the time.
Oh and love the quote on do go fastter then you want to hit it thta's great I so have to remember that.
