robertpage101
Thread starter- Joined
- Aug 2, 2008
- 31
I have a leeky lower unit on a 89' evenrude 150xp. When i hook it up to the hose it shoot water out the crese between the lower unit and the i guess the shaft housing in the middle on both sides. I tightened the bolts but nothing got better. Is their a gasket i need or is the water pump leaking or am i not even itn the ballpark. next i did a compression test yesterday and i got the following
65 65
70 70
68 70
is this okay i know it is the ration between them but im not sure if it is the the tester is week or the low reading is just the compresson of the cylinders. One more thing is how do i test the rpm gage. I have good ground and ignition also the lights work but when the motor is running i have notting on my test light when i touch the wire used for the tack???
thank you
65 65
70 70
68 70
thank you
