Leaving my boat on the river
biglurr54
I am going to be leaving my boat on the Hudson river in ny for a few weeks this spring. I have a dock about a mile from my apartment and it will be perfect for the stripe bass run. Beats trailering it every day. I have never left my boat on a body of water for very long so I'm not sure what to do. It's in a city setting and there are bars that over look the dock. I want as much protection as I can. The boat is a 18 foot crestliner. Open bow. I have a new bilge pump with a float switch. I wired the float switch to a switch in the dash but I have sense became a boats member and learned to wire directly to a battery. Now I have an battery switch so I can turn the battery off and the only draw at that point will be the bilge pump. I have heavy hatch braid for all my lines. Main and spring. I have good bumpers as well. I just ordered material to make a mooring cover for it so it will be covered. I will remove anything of value in the boat that's portable. What else should I do? Should I chain it and lock it? Anything else I'm forgetting?
cribber
Re: Leaving my boat on the river
Is there shore power available? I'd pop for one of those battery tenders to keep you battery at full charge and the mooring covers will go a long way to protecting your boat from rain and prying eyes. Getting to know the bartender at one of the bars with a direct view of your boat would also give you piece of mind.
scoutabout
Who owns and manages the dock? Can you get a sense of the history for vandalism, etc? I like the idea of getting to know the people in the businesses that overlook the dock. You want to make sure the place is ok.
Sounds like your boat prep itself is well planned. You may want to run a backup battery but it doesn't sound like it will be sitting long. As for a chain it's pretty hard to lock a boat to a dock unless you can get a chain around a piling or something. Even then, most can be snipped in half a tick.
If you are having a tonneau cover made, get the cockpit section to come up over the windshield. Protects against UV and prying eyes.
Mine is a two piece so I can still keep the bow covered in bad/cold weather but the rear section covers the windshield. It overlaps the front cover so rain doesnt' get in (sealed with velcro along that area).
If I was doing it again, though I'd tell the guy to take the material right to the edge. I'm slowly developing a strip of oxidized fibreglass around the outer edge of the boat. :(.
On the up-side, the material is Sunbrella, so at least it should last and he sewed it triple thickness wherever it contacts the windshield frame.
NYBo
I live not too far from just such a place, in a city with a not-so-good reputation (Newburgh). However, the waterfront has been cleaned up and is well patrolled. Take a look at the boats being moored around you. Unless yours is by far the fanciest, most expensive boat there, I don't think you have to worry about vandalism or theft.
mr 88
Can you have a dock box at your slip? Those truck boxes work good for that and can be secured to the pier so they do not walk off with everything. Also you should ask what kind of water fluctuations there are. You do not want your dock lines too tight or loose for that matter.Most people that go to the water type bars have zero interest in ripping a boat, if anything they are good for keeping the riff raff away.
NSBCraig
Don't forget zincs!
If it's going to be sitting around other boats with shore power your really gonna need them.
Home Cookin'
advice from one who always moors boats:
#1 is that you are only a mile away and therefore can address any unusual situations, and can run the boat often. It would be a different strategy if it were 2 hours away in a remote location.
You have the right approach for the battery, bilge pump and cut-off. Do not add a charger and power; you don;t need it and you are going backwards. KISS. The less that can go wrong, the better.
The only way to know how to moor your boat is to ask an experienced person on YOUR dock. I personally believe that a boat should be tied so it doesn't need fenders, but I know that isn't possible in all situations. But try.
Covers serve different purposes, so figure out your needs:
A cover keeps out rain--not necessary since you have a pump but a good idea.
A cover protects your soft interior: cushions, carpet, instruments. If that's important to you, or your boat requires it, go that route. My boat is set up so all I need to cover is the console, not the rest.
A cover protects your hard surfaces from sunlight and dirt--few people care about this, and a fully covered boat is a pain at a mooring. Remember, you aren't under any trees. You might, however, be downwind from a coal pier.
A cover keeps your stuff out of sight, and it is less likely to get stolen: the typical boat theft is the crime of opportunity: someone grabs a boat hook, a hose or life preserver b/c he lost his; they may grab a toy like a tube or wakeboard.
First, talk to your boaters about what kind of theft goes on, and set up accordingly. Me, I'd risk a $60 tube under a cover b/c it's a pain to haul home and store, but not a $200 wake board. Same goes for electronics. I'd remove the stuff that is on brackets (not the compass) and not worry about the mounted in-dash, except to cover it. Consider a small padlock on a hatch cover as well, to protect things like PFD's, if they aren't under a cover. Again, you are just trying to prevent the grabbers--enough to keep an honest man honest.
As for stealing the whole boat, take your key home, and that's about all you can do. There is no effective way to prevent a tow-off (but again, talk to the boaters nearby). My guess is the most likely thief is someone who wants to take your boat out for a joy ride, so don't hide a key, and keep an eye on your nephews and daughter's ex-boyfriend.
A dock box is a great idea (some piers don't allow them) but don't leave valuables in there (wakeboard, electronics). The guy who will jack the lock won't take your PFD's and hose and mop.
