05GlastronSX
- May 29, 2005
- 437
to me this doesnt look normal. this was the first time we have had the boat in the water and when i took the pictures from behind he boat sitting in the water this is what i saw... if you are standing inside the boat, facing outward towards the engine, you have a full 3 gallon oil tank on your right side, the bilge pump in the middle, and a heavy duty marine battery on the left side. i dont know what could cause it to lean like this. the boat has no gear in it except for 8 life jackets which would not weigh enough to make a difference. also my gas tank is 23 gallons and this was pic was taken with less than 10 gallons in the tank. i have no clue where it is located either...maybe its on the left causing it to lean? <br /> <br /><br />
<br />
