Lean sneeze
nickmo
I know there was a previous thread on this not too long ago. Think it was Cousin Abe's. Anyway.
1999 L225TXRX All typical ox 66 maintenance done this spring. Motors run great. When starting starboard motor, it does what it's supposed to do then sneezes once and stalls. Start it again and idles perfectly. BTW it's done this for a couple of years.
waffles1
Re: Lean sneeze
Sounds like the motor is loosing prime which good be from several things. Pump the bulb up good next time and see what that does. Good Luck!
rodbolt
Re: Lean sneeze
do all the normal checks for coolent temp sensor,crank posistion sensor and TPS voltage.
nickmo
Re: Lean sneeze
Will do those tests.
Thank you.
