Re: Leaky wooden boat
Jeff,<br /><br />As one "addict" to another ( I own two of those wooden holes in the water ), the first step is to determine where the leak is coming from. Is it obvious ( i.e. a high water mark, etc...)? If not, then, while in the slip, you need to open up the floorboards, plug all of the limber holes in your frames, vacuum out all of the water, and watch where it accumulates. This will give you a good idea about what to do next, based on where/why it is leaking.<br /><br />Good luck,<br /><br />Scott
