Late 80's 200 Johnson tilt/trim problem
Mako68
I have a 86 Mako with a 200 Johnson outboard. Motor trims fine and holds forever in the yard or on water, but will not trim while motor is in gear running. I can stop and trim motor but as soon as I give it throttle it pushes motor back into transom. Any ideas? Fluid is full and bled and haven't touched manual let down screw. Everything else works fine
wrench 3
Check to make sure that the manual release valve is tight. If that's OK then the hydraulic unit will have to be rebuilt. You have an "O" ring or a valve leaking inside the unit.
