I have a 86 Mako with a 200 Johnson outboard. Motor trims fine and holds forever in the yard or on water, but will not trim while motor is in gear running. I can stop and trim motor but as soon as I give it throttle it pushes motor back into transom. Any ideas? Fluid is full and bled and haven't touched manual let down screw. Everything else works fine
