Larson cabrio 370 2004
Paulg9306
I just bought the boat and have a question about the dual fuel tanks. The boat broker said each engine draws from separate tanks…but that does not appear what’s happening. I haven’t used the generator yet but I know that’s supposed to draw from the starboard tank. It appears the engines are drawing primarily from the starboard tank so far…can anybody confirm or elaborate?
Nheels
I have an 08 Cabrio 330 and can confirm that each motor draws from it's own tank. I have noticed that my stbo motor burns a wee bit more fuel then the port one though, so the gauges are never even. Apparently the gauges can't Soley be relied upon as well.
Paulg9306
Thanks…another question if I may. On the bow deck near the windlass is a hose fitting with a cap. When loose a pressurized water stream escapes….what is this fitting for?F6098BAC-5603-41F6-9E35-5DEBEE4F9058.png
Nheels
I'm taking a guess here, but maybe it is to wash the chain and rode if you are using it in seawater so that to avoid corrosion.
