Re: Large Dent Aluminum Hull Bass Tracker Repair???
Let me start out by saying that I do NOT mean this in any way as a statement of disrespect or the end all to be all...
it is just one guy's opinion and I am only putting it out there for consideration...
Most of the guys here have walked away from cheaper, better condition boats...depending on your location, if boats are rare and hard to come by, this might be a good choice for you, if there are boats a plenty...keep shopping...
It isn't a matter of the guy is using it like this and he has had no problems...
I am giving you this advice from a collision technicians perspective...I work on wrecked cars all day long and I have been working on cars for 39 of my 50 years...I have come to the unwavering conclusion that no two people treat their personal items exactly the same way...what I mean by this is the following...
While John Doe drives a certain way in his car and everything is fine, one day he decides to sell his used car, you come along and find that while the car has a couple of issues, the price is right and you buy it...
BUT, you drive differently than Mr.Doe and in no time at all problems start popping up...doesn't shift right, doesn't seem to have enough power, A/C or heater doesn't work, doors don't close right, whatever...next thing you know, you are thinking, man what a piece of junk...this thing is falling apart...
It is not John Doe's Fault, the car's or yours... it is a phenomenom that I have come to expect from any device made by man...it takes a set...it gets worn in or broken in a certain way, and when someone else starts to use it differently, things start to go wrong...
So my moral to this story is...even if Mr.Doe's car has a bent Frame and he is driving it everyday, back and forth to work...and it is working just fine...
When you buy the car from him, you may use it differently than he did and find yourself in a world of financial hurt...
Now this is not to say, that you have great luck, buy this boat and spend a ton of years using it and having fun and showing us all what goofs we were at trying to talk you out of this, but you are taking a chance that this may not be the case...
The boat in question has structural damage...
Not cosmetic...
Yes, most anything on the planet can be fixed...
When a vehicle, any vehicle, boats, cars, planes...takes a hit that hard, the entire structure of that vehicle suffers some damage...
While it may not be readily apparent now, it is there and it won't fix itself...
You don't want to be more than a few hundred feet from shore and have a major structural failure on your boat...
If in the end you are absolutely certain that this is the boat for you, and you can negotiate a fair price for it, make the deal CONTINGENT on having a certified Marine Appraiser check it out for you...If he says its fine, then go for it...
And by all means, if you do end up buying this boat with the assurance of an an appraiser, Please, post back and rub our proverbial noses in it...
Best regards,
GT1M
