King Starboard
reelfishin
Re: King Starboard
I thought about 'padding' the new floor where it mounts but figured that would both hold salt and harbor corrosion and be a problem as what ever rubber I used aged or shrinks. The real problem comes from the drum effect if there's a hollow area below the floor. Sort of like banging on the bottom of a tin can. On the factory aluminum floor boats I've looked at they've poured in foam below the floor that deadens the sound. I haven't had one apart, but sort of picture them as being solid foam below the deck. I can see a piece of PVC pipe protruding from yellow flotation foam on my buddies boat back at the bilge recess and there's excess foam showing around all unwelded seams as if they just pumped the lower hull full. While that adds lots of strength and keeps it quiet, it's a nightmare when the foam gets wet years from now. His boat is all welded, no rivets at all.
Another thing I have to think about is color, it will have to be a very light color so as not to become a floating frying pan in the hot sun, but making it too light and it becomes a huge reflector that will cook me and whoever happens to be aboard with reflected sunlight. I am thinking maybe a light gray with very little gloss if possible.
tmcalavy
Re: King Starboard
The guy who owned my last boat before me made removable floor panels that were great. Ran wood runners parallel to the stringers and put tongue-n-groove deck board across them, cut to fit the width of the boat. Made a very stable deck and could be removed to get the crap out of the bottom of the boat when necessary. Best thing was we could set up folding camp chairs between the bench seats once we got anchored in for fishing...nice and comfy, back support and a place to put your cold refreshing beverage. Made the boat more stable, too....the removable deck, not the beverages.
jeeperman
Re: King Starboard
There is another thread about a boat made of aluminum roads signs.
Which gave me this brain fart.............
The really big interstate green faced signs are now commonly made up of extruded aluminum planks. They are bolted together to make the large signs.
The planks are 12"x2" and 6"x2".
If a scrap sign could be found in the scrapyard..................................
ftp://ftp.odot.state.or.us/techserv/roadway/web_drawings/traffic/pdf/tm675.pdf
GregE
Re: King Starboard
I was told some people use old road signs. I thought they were steel. I guess things are moving to aluminum. Gotta call my local DOT and see what they do with old signs. (if aluminum of course)
