OK, last year I replaced what looked like the OEM starter on my 96 5.7 merc. symptom was the starter motor would spin but not engage the flywheel. I figured the solenoid so I ordered a new "offbrand" starter and it worked. Last year when trying to winterize the engine wouldn't start. Cranked and cranked and then starter did same thing as last one, motor would spin but not engage the flywheel. Figured I burned out the new starter and winterized and forgot it. Problem is still there now that the boat is unwrapped. The odd part is that I have both starters and when testing them out of the boat they seem to work. Applying 12 volts to the solenoid throws out the pinion gear, jumpering the leads and the gear comes out and the motor spins. The starter was still tight when I removed it so it did not move away from the flywheel. Checked for broken teeth on the flywheel and starter and nothing found. What am I missing here? I have no way of putting a load on the starter to see if the gear spinning on the starter motor shaft which is the only other idea I have.......
thought of pop starting it but I cant push the boat fast enough
