clemsonfor
- Sep 19, 2005
- 1,011
A boat I sold to a buddy was either not starting or cutting off, I cant remember, I told him to check that black/yellow wire to make sure its not randomly grounding out, which it was so like said check it out. I would also disconnect it and run another wire to see if its not internally broken or randomly grounding when not suppose too.
Yes you can temporary disable the kill switch for testing or you can disable the black yellow kill wire and just have to reconnect it to kill it or some other way to cut it off. Just be sure to reattach your kill switch if you choose to wear it, I had a buddy driving a boat in training and a person was thrown from it and the guy was killed, because he forgot to attach his kill switch.
Also if you pull the flywheel you will need a flywheel puller or one that looks like a steering puller. Not a 3 jaw puller but one that screws into the bolt holes in the top and pushes from the center.
