Spectrum156
Thread starter- Joined
- Apr 6, 2016
- 2
I have a Pride Pathfinder Half cabin fiberglass boat and I need to replace part of the trailer. The trailer is a bunk, keel roller tilt trailer with a 75mm (horizontal orientation) by 50mm (vertical orientation) tongue running the full length of the boat which has 5 keel rollers welded to it, except for the back most roller which is adjustable. (Structurally I know it is better for the longer side to be vertical but this is how the trailer was built.) I will be replacing this piece with a 5mm thick RHS of the same size and having 10 keel roller brackets welded,(I was just going to use brackets with holes and U bolts but been having trouble finding some) with red keel rollers. It currently has 4 1/2" brackets with rubber cotton reel rollers. Seeing that I am replacing the brackets should I go with larger brackets and rollers? Another problem is that the last 2 1/2" of the keel is higher that the rest of the otherwise flat keel by about one inches. How can I support this from the keel tongue? Trailer tongue extends past rear of any cross member by about 3 feet.
Trailer body is being sandblasted, coated in cold gal and paint with 2 coats of epoxy enamel.
Any help with suggestions would be greatly appreciated
