I see potential problems with my glassing technique. I'm repairing my keel, ( three -length wise cracks in the keel ) - previously repaired from the outside. Not by me! Anyway I started by grinding out the area about 7" up eachside and removing all the broked and frayed bits. ( from the inside)
The result was a pretty chewed up centerline - uneven and a bit of under cutting, (went right through once) So I read fiberglass hates sharp angles and voids etc, So I figured I'll fill the unevenness with epoxy/cabosil mix. I made a spatula out of thin plastic (wiped out the area w/ acetone) wet the strip 2" wide with epoxy and put a nice slightly concave fillet of PB in the keel While it was wet I mixed more epoxy and put in a 14" wide path of 6oz cloth x 5ft long to make up the thickness I took out with the sander (Note I hope epoxy works w/ this stuff.) I followed that with 24oz woven roven 10" wide and another 10" cloth.
Should mention all layers were put in while the epoxy was wet or in semi-hard gel stage. Used a slow hardener and no overheating noticed in fact its only 60F in the garage and the stuff takes a bit longer to set than says on the bottle.
By the By I using SystemThree non/blushing marine grade. Dang EXpensive here. Paid $213 for 1.5gallon. but seems to work nice. I'll change to west product when I run out.
So next I put in 5" wide strip of 24oz woven roven and 5" wide 6oz cloth again. I thought I'd feather the widths to prevent the hull from getting too thick and stiff. I still have to repair and layer the outside of the keel as well.
I looked for ideas on what layers to use and just recently saw that epoxy needs special matting ( bought plain old mat I don't think its epoxy rated thank goodness I didn't put it in)
Guess I need some one to tell me if I used enough, too much? Did I do good or what?
