Keel Extension
polarisjunky06
Just Bought a 1975 Trojan f26 and the original owner had added 8 inches on the bottom of the keel starting from the front all the way to the back this brings up my question will adding this keel extension help or hurt in reguards to planing,"stability",and well just all around drag issues. As aresultof this the boat will not go above 3100 Rpm and wont go over 16 MPH it has a 14x10 non cupped prop this is a bad issue when u want to go to stellwagen bank and it take 2.5 hrs to get there any help would be awsome
abj87
Re: Keel Extension
Punctuation would be great. Re-write your questions so we can actually READ it and we may be able to help!!!
Randybeall
Re: Keel Extension
Please include your engine, horsepower, and approximate weight of your boat. It sounds like you have a serious under power problem.
slasmith1
Re: Keel Extension
post a picture it is worth 1000 words at least.
LIQUID PROZAC
Re: Keel Extension
welcome to iboats and read the sticky at the beginning--things to know before you post-- give as much info as possible
Ned L
Re: Keel Extension
The only way I could see that kel addition affecting the performance is that it may be messing up the water stream to the prop. How is the back end of the keel extension finished off? If the trailing edge is plumb & cut off square it may be causing some problems. I don't see that as being the difference between say 14 knots (16 mph) and 20 knots (23 knots). -- Oh yes, you said the engine won't do more than 3100 RPM, I can't see the keel extension causing that problem. If the engine is anywhere around 300 CID I don't think it should have a problem turning that prop (it's not oversize). Is the bottom clean? is the prop clean?
Les Robb
Re: Keel Extension
Trojan's are well engineered and manufactured boat's, do you have any clue why someone would add an additional 8" to the keel? What's it made of mahogany or laminated wood strips. Unless the previous owner decided it would some how or other soften the ride in head seas or help prevent rolling I can't imagine why the modification was done.
Would like to hear if you have talked to owner or broker about this
PS no way can you add 20 some odd feet of 8" keel and improve planing. (Unless composit that's a bunch of weight) How wide is it anyway?
