Just rebuilt a lower end on 1965 Ski Twin
1946Zephyr
Had another one of these "jumping out of gear" motors. This motor just happened to prove one of my earlier points about this issue. Don't automatically assume that it's a clutch dog creating the problem. The guy that brought me the motor went to a dealor/mechanic and they quoated him $400 for parts and not counting labor. I laughed and told him to bring it on over. Well, I had to re-seal the lower unit anyhow, because when I dropped the drain plug, a buch of nice clear water ran out and then some yucky grey gear lube. Well, once I had the lower end off, I checked the upper shift rod and sure enough, there was more slop in it, than the law would allow. I have to pull the powerhead and tighten the bellcrank bolt that holds the shift linkage. Bottom line is guys.....look here first, before you condemn the bottom end stuff. This is a common problem on these old type I lower units and this is where I usually check first, before I tear anything down. I only tore this one down, because the seals were shot and it had a large supply of water intrusion. Fortunately though, all the gears and bearings looked good and this ol' boy won't be out anything, but a re-seal kit.:cool:
Had he went to the original place that gave him the quoats, they would have missed the real problem, most likely.:eek:
