Just put new Waterpump in. Have a question
Friscoboater
I just installed a new waterpump in my 81 Pre-Alpha drive. I installed all the new gaskets and put a little lube on the impeller and turned the shaft clockwise as I installed the housing. I then tightened it all down.
My question is how hard should it be to turn the shaft after the installation? I have to really twist hard to get it to turn now. Is that just because it is new?
Gary H NC
Re: Just put new Waterpump in. Have a question
That is common...run it and don't worry as long as it cools good.;)
Friscoboater
Thanks
I just wanted to make sure that I did not tighten the blots down too tight.
Friscoboater
I cannot find torque setting for the WP nuts. Anyone know?
Rocky_Road
Forward nut= 35 to 40 in. lbs.
Middle nuts= 25 to 30 in. lbs.
Rear screw= 15 to 20 in. lbs.
Happy boating!
Friscoboater
Really? That seems high, but cool. Thanks
bigskiohio
Master Chief Petty Officer
inch pound not foot pounds
in. lbs ft. lbs
1 inch pound = 0.0833333333 feet pounds
your talking about 3.3 ft lbs and less
Friscoboater
Ohhhhhhh. That makes since.
