RudeRunner
Thread starter- Joined
- May 8, 2006
- 7
Hello all,<br /><br />I just finished rebuild the lower unit on my 1980 Evinrude 9.9. I replaced the water pump impeller and housing, all driveshaft seals and bearings, new o-rings, gear oil, etc. I lake-tested it today. It runs great and pumps plenty of water. The only thing is a weird noise when it's in neutral. It sounds like meshing gears. It is not a whine, grind, or squeal. The only way I know to describe it is it sounds like some car's power steering when you turn the wheel all the way to one side or the other. Kind of a humming sound. It goes completely away when I put it in forward or reverse. Is it maybe just the new water pump I hear turning? It goes into gear very smoothly with no clunking or grinding. I hope I didn't screw something up. I did not remove any of the gears, shift linkage, etc. when I dropped the lower unit.
