Just bought mariner 70hp that wont start without screwdriver
marine11
I bought a mariner 82 model 70hp, and the ignition key wont turn over, there is voltage in the ignition switch.
i read in the manual that there is a start switch, although i cant find it, and would this stop the ignition switch from turning it on.
also the rectifer is another thing i cant locat on the motor and would this stop the motor from being started also.
i can use screwdrive on the 2 bolts on the stater solenoid and it start though.
Dave1027
Re: Just bought mariner 70hp that wont start without screwdriver
Try hot wiring at the switch to confirm you have a bad switch.
Follow the yellow wires from the stator should lead you to the rectumfrier.
CharlieB
A test light or volt meter will help you sort this out.
First, check the fuse located near the starter relay to be sure the ignition switch has 12 V on the Red wire.
Have a helper hold the key in the start position and check for 12 V to the starter relay trigger wire, yellow with a thin red line.
If 12 V replace the relay.
If NO volts then test the same yellow W/red line on the ignition switch, it should show 12 V when turned to start, if none replace the switch, if 12 V then check the Starter lock-out switch in the control box. this switch is on that same yellow/red wire and only makes contact when in Neutral.
marine11
Thanks everyone who replied, i have sorted it out, i diagnosed the stator solenoid and replaced.
now starting.
Thanks
Dave1027
Just a little electronics geek humor. It's an old one. :D
