just a little more help needed.
mike8890
I got my new starter for my new motor I put it in and it fired right up no problems. I shut it off then this morning I went to start it and it acts like a low battery so i put jumper cables on it and it still won't turn over fast enough to start it and the positive wires are smoking what could it be. It a 95 4.3 mercruiser
fmalott
Re: just a little more help needed.
i'd say take the starter back. make sure your connections are clean. also are the positive wires the proper gauge
Don S
Take the spark plugs out of the engine and see how it turns over.
Ayuh,.... Clean the wirin' ends, or replace the wires,...
Heat, equals Resistance......
mike8890
Well i pulled plugs and it still turns over slow little faster but not fast enough
Don S
Can you turn the engine by hand?
mike8890
Not by hand but with a socket its a brand new motor
Don S
Have you tried since the starting problem with your new starter? If you did, and it still turns easy. Take the starter back.
mike8890
Ya it turns with a socket pretty easy and ok ill try it thanks ill let you know
