woosterken
- May 18, 2005
- 1,431
Re: Joza's 1957(?) Red Fish Restoration
Joza,
Great little project
I sent you a PM
hope it helps
woosterken
Joza,
I sent you a PM
hope it helps
woosterken
Looking good! Make sure you check that the Rusto garage floor coating can handle the potential flexing of wood. I'm not sure if it works mainly on concrete. I'd hate to see it end up cracking all over on you.
Holy crap!! Your moving fast. Good work. Just a note about the rustoleum garage floor paint. It is an epoxy paint. From what I have heard epoxy wont stick to well to polyester (depending on what you used for the deck). Also that stuff is not a non skid coating. I am using Durabak on my deck that I am going to do this winter. Just though I would give you some info.
Your 1.5" is more than enough to handle that motor. Project's looking great.
The ply transom should be completely glassed, if you used resin without glass it (resin) will crack and the ply will get wet.
Also grind the air bubbles off and re-glass over them,
the cloth doesn't look heavy enough, could just be the pic...
but I'd go back and do a minimum of 3 layers tabbing the transom to the hull. each layer being wider than the previous to spread the load from the transom onto the hull.
If you are using waxed resin you'll need to sand the wax off before the next coat goes on.
If its unwaxed resin just a wipe with acetone will be ok.
