johson super seahorse 33 model
niel norman
hi i have johson super seahorse 33 im not sure of the model because the plate with the model number has worn off or something
It says on a silver disc on top of the power head A038058
It also says on the case undernieth the motor 309065
Can any one help me because i need the model number to get parts
F_R
Re: johson super seahorse 33 model
Any chance that thing was made in Australia? The number on the disc is the serial number, but the "A" probably means Australia. USA Serial numbers ran much higher.
At any rate, the 33 was made from 1965 through 1971. There isn't much difference over the years, but there are SOME differences. Depends on what you need to order.
niel norman
Thanks I would not have a clue where it was made i don't know the history of it but I need a impeller and the o ring for th shaft at the power head end and the seal in between the water pump and gear box thanks
jay_merrill
Post a few pics of it - we might be able to at least make a guess on the year based on paint color, hood decals, etc. Also, if all you need is an impeller and a drive shaft o-ring, I don't think its going to make much difference what year it is. That, of course, assumes that it really is a 33hp model.
1946Zephyr
yep, that lower unit was a long time in the making. 1955 up into the 70's, 25, 28, 30, 33, 35 and 40hp motors, so getting parts should be simple.
niel norman
whenever i try to get parts for they say they cant give me anything without the model number they wont even match parts
1946Zephyr
Yea, you should post some pics and someone here can narrow down the year of your motor:cool:
jay_merrill
If its a US made Johnson 33hp, it will be one of these models:
Year: Model
1965: RX-RXL-13, RXE-RXEL-13
1966: RX-RXL-14, RXE-RXEL-14
1967: RX-RXL-15, RXE-RXEL-15
1968: RX-RXL-16, RXE-RXEL-16
1969: 33E69, 33EL69, 33R69, 33RL69
1970: 33E70, 33EL70, 33R70, 33RL70
niel norman
hi i found another numbe on the power head its on the bottom right hanside if your standin behind the boat it either 55088 or 65088 anyone know what this could be thanks
niel norman
here are some pics
niel norman
and some more pics
jay_merrill
While it appears that your motor has been painted one or more times, the hood appears to be off of a 1967 Johnson 33hp - maybe a 1968. I can't remember exactly which year had the silver "seahorse section" on the side decal, but the 69s had gold in this area.
I'm thinking '67 or '68, bcause of the Forest Green paint below the trim piece. This went with the green color of the rest of the motors, for those model years. Once again, I'm dealing from memory, but I think the '65 and '66 33hp motors were all white.
1946Zephyr
Tell them to take a flyin' leap. You can get your impeller and your 0-ring here at iBoats.:cool:
If iBoats doesn't have what you're looking for then go to vintageoutboard.com
sounds like jay_merrill has it nailed down for ya though.;)
jay_merrill
For what you need, I really think you would be OK with parts from any of the 33hp model years.
As F_R correctly pointed out to me not long ago, there are some parts differences between the 28hp motors and the 33hp motors (they are essentially the same motor and share many parts), but when it comes to stuff like impellers and drive shaft o-rings, my bet is that there aren't any substantial differences. Since I have been wrong before, however, just verify this from whatever parts source you go to - they should be able to tell you quite easily.
One thing you might pay attention to, though, is difference in complete water pump kits. For example, the OMC 6hp motors can have "small" impellers or "large" ones - it just depends on which kit your get. The difference is in the size of the cup in the pump cap. The last time I ordered an impeller for one, I forgot about this and ended up with the wrong size for the pump cap/cup that I had. No big deal, because I just decided to bring the impeller back as an individual item and buy a whole kit, which is what I probably should have done in the first place.
I'm not sure that this is an issue with the 33hp motor, but its a good thing to keep in mind.
1946Zephyr
yep, that was the option I had with my 6hp too. I could have bought the original style impeller, but I opted for the newr style kit all together.:cool:
F_R
Yep, you have a 33hp, year uncertain. BUT, the water pumps are all alike on all the 33hps. Go to http://shop.evinrude.com/, navigate to the 1968 33hp, pick out the parts you want and order them there. Or, you can get them here at iboats also.
