johson 60 hp
coopdvl
been sitting, wont start, cleaned carbs, checked fire, and commpression, sprayed fuel right throught carb and still did not start.1990 tracker
tashasdaddy
Re: johson 60 hp
model # please. when was the last time it ran,
JB
Re: johson 60 hp
Yup, that's a 1990.<br /><br />Go to Engine FAQs, coopdvl. Do the troubleshooting in there.<br /><br />Good luck. :)
Dhadley
Re: johson 60 hp
Welcome!!<br /><br />Go to the main forums page and it's at the top. <br /><br />I see you checked for spark. But you didnt say if it was there or not. We'll assume it was, right?
coopdvl
Re: johson 60 hp
have to check fly wheel key is this common problem with ones that have been sitting?????
Dhadley
Re: johson 60 hp
Not common but not unususl. Usually it's carbs but you said you cleaned them. Did you install new kits?<br /><br />Do you have spark?
coopdvl
Re: johson 60 hp
yes new kits but also can not even get motor to try to start when spraying fuel through the carb wont even try
Dhadley
Re: johson 60 hp
Again -- you checked spark. Does it have spark?
Silvertip
Re: johson 60 hp
Either you don't have any spark or its very weak, or as was mentioned, the flywheel key has sheared or begun to shear which upsets timing. With fuel, air, spark and proper timing it has to at least attempt to run. You are missing one or more of the above.
Silvertip
Re: johson 60 hp
One more thought -- did you check spark on ALL cylinders. If you are spraying fuel into a cylinder with no spark, the other cylinders will not fire if there is a fuel problem. Are the plugs getting wet? If so, you have a spark problem. If not, you have a fuel problem.
coopdvl
Re: johson 60 hp
fly wheel key is good i have fire on all three cylinders, will check for the plugs to get wet after i turn it over, not spraying any fuel....
Dhadley
Re: johson 60 hp
When you cleaned the carbs what did you soak them in?
tashasdaddy
Re: johson 60 hp
did you blow out all the orifice's w/compressed air?
Dhadley
Re: johson 60 hp
Are you sure you have spark with the plugs in?
