Ok thanks. Any tips for not letting it get away while winding. There really isn't much to grab hold off. What do you do, use a length of wood between the cogs and to turn for leverage? Also, when I put nail back in hole what will it catch on. Guess there must be something in the housing casting that it will catch on, but can;t see it now with the recoil on, but will take your word that it will catch something.
I don;t suppose you have a video of how you wind them up? I still can't quite picture how that would be done while holding the housing, loading up the spring and the threading the pin in the center spring hole essentially blind as you can;t see the pin once you put the recoil over top all while not having the bold in as with the spring unwound the bold can't fit. I've only done the one now and it was a pain so believe there is an easier way, just can;t quite figure it out. Anyhow, that is done now so more interested in how not to break by spring when I wind it up for the rope. Appreciate your experience! tks
