johnson tach question
lehkyc
iv got a 1975 johnson 70hp. can i run a quicksilver tachometer on it? someone told me running a wrong tach can really mess with the motor's electric. is this true?
Haffiman
Re: johnson tach question
If a Quicksilver OUTBOARD tack with a 6pulse setting, you may use it.
eavega
Tach shouldn't put any inputs in a motor's electric system. The only connection to the motor is via the pulse wire (grey wire in your control). As the previous poster said, as long as its a 6-pulse tach, you are good to go. Wire power to your dashboard, grey wire in the control is the signal.
Rgds
lehkyc
Eric Vega, thank you man! you have answered many of my forum questions the past week. your responses have been very helpful. thanks for helping me out
