Johnson short shaft questions
wellcraft26
For those of you experts with older johnson outboards I have a few questions.
I've been looking for a 70hp 15" short shaft engine for a 130 bullet boat I'll be rebuilding. So today, I bought what I was told it was an early 1970's 70hp 15" short shaft but after I got home a did some research and found out its actually a 1968 55hp. I never thought it would be that hp because as far as I understand 55hp (model# 55872R) are 2 cylinders, I guess that's on newer engines.
Anyway, my questions are:
The engine is a short shaft with an extension but when I removed the lu I realized that it does have a 1 piece shaft and not a short shaft with an extension. How could I work around it so I can put it back as a short shaft?
I wonder if the 55hp engines were offered with a short shaft 15" version or If this is a swap or something like that?
I assume no but could I swap the mid section with new 1980 1990 70hp johnson engines?
I contacted the seller as soon I realized this wasn't a 70hp and he told me it was sold to him as one, he also told me that the only difference between a 55hp, 60hp and 70hp is just carbs, is this true, I would think that there most be other differences between them?
If i get another older 70hp, can I swap with mid section and transmission from that 55hp to the 70hp?
Thanks in advance, any help and advice would be greatly appreciated.
The early 3 cylinder 55 was offered with a short shaft for 15" transom.-----The early models ( 68 and 69 ) only had 2 intake ports.-----Later models were 60 HP and had 3 intake ports.-----So the seller is stretching the truth.----The seller does not know the facts !!!!
wellcraft26
That's what I thought, do you know if I can make the 15" mid section work on a newer 70hp johnson, like from the 1990's ?
BTW, thanks for replying
The 70 HP was never offered with electric shift.-----Only the 3 cylinder 55 in 68 // 69 and 60 HP in 70 and 71 and 65 HP in 72 had electric shift.------the newer 70 hp block will not fit on a 68 midsection.
wellcraft26
Ok, thanks for the info. Looks like I wasted some money. How about if I find a 75hp stinger, could i swap the mid section?
