Johnson Searunner V6 200hp from 1996
Zeebonkie
Hello,
I am from The Netherlands and i need a brochure or technical specifications info where you can read that an Johnson Searunner 200hp V6 from 1996,indeed 149 kw or 200hp can given.
I must have that because I wanna go fisching for my job so the engine must be writen in the fishregister but i need the technical specifications!
So please who can help me??
(Excuses for my Englisch)
Greetings Ron
Bob547
Re: Johnson Searunner V6 200hp from 1996
The technical specs are printed in the factory service manual. Also, the factory service manual is a good thing to have in case your engine breaks down and u need to fix it. Try looking on ebay to find one. Hope this helps, Bob
Ron, Marineengine.com sells the manufacturer's service manual, the owners manual and the parts list, for that motor.
There should also be a sticker on the port side of the motor with model number, serial number and some other information.
dingbat
I have the 1997 Evinrude version of that same motor. The OEM service manual lists the output of that motor at 149.2 KW @5500 RPM
Zeebonkie
Dingbat,
Do you also know how many petrol it used when your speed is 25-30 miles/hour?
Thnx Ron
