Johnson Seahorse 3hp
Steve A W
Re: Johnson Seahorse 3hp
Chris
You need to use a marine oil mix, marked TCW-3.
Probably a 24to1 mix[someone will correct it if I'm wrong]
Chainsaw mix is for engines that run hotter[air cooled vs.water cooled]
Good luck.
Steve A W
tx1961whaler
Chris
Good luck.
Steve A W
The 1959 JW-15 started out life as a 16:1 mix motor. No roller bearings, so a rich oil mix is a must. Definitely use TC-W3 oil; not chainsaw oil.
1946Zephyr
Yes, 16:1 which is 8 oz. per gallon. 24:1 is the very least, but 16:1 is better
Chris52796
Well you think starting spray would make it start instead of gas and oil
nwcove
starting spray is for old diesels!! (jmo). and if you use it to start your 2 stroke motor you will damage it....there isnt any lubrication in the spray can!!!
Chris52796
Going to put the carburetor on and see if anything happens if I dosnt I will wait to next year because winter is here already
1946Zephyr
What? You haven't talked the wife into letting you work on it, on the kitchen table yet? :D:D
HighTrim
Apparently that is unsanitary Zephyr, geesh! (Or so I have been told by my wife)
Start with the basics here.
What is the compression exactly? If compression is fine, is there a healthy blue spark that will jump a 1/4" gap on an inline tester with a bright blue ZAP!!? When it will not start and you pull the spark plug is it wet? If not, spray pre mixed fuel (NOT starting fluid) into the cylinder then try again. If it now fires you have a fuel delivery issue. That may need to be adressed with the carb rebuild, but can discuss that once we pinpoint the issue.
losnbama
chris52796,what they're trying to say is ,that unlike a car that uses oil pumped thru the engine and stored seperately in the oil pan.this motor does not have that.so one must mix the correct ratio gas:eek:il to insure proper combustion as well as proper lubrication...you say you have moved the coils???have you reset the points(.020) to open at tdc???
Chris52796
Coils are not moved
Points are set at .020 at TDC
1946Zephyr
I know Chris. I was just kidding. :D I dont do the kitchen table thing either. I have my man cave for these kinds of activities.:D:D
Chris52796
Still havn't put the carb, in so soon I will put it in so It better work or I will make it work no matter what... Lol
