Johnson Seahorse 20hp (1984)
rbro79
I have recently bought a seahorse 20hp. It hadn't run for 2 years and wasn't flushed after it's last use. Needless to say I didn't hold out much hope.
However, to my surprise, it started on the third pull and ran without any problems for 2 hours straight before I took the boat out of the water.
The only problem was a lot of smoke/steam, and I mean an unusual amount. Could anyone suggest a reason for this? I thought it may be a rich air/fuel mix but am not to good with outboards.
Any help would be great
Cheers
Russell
P.S. Am using a 50:1 oil mix and good quality oil.
R.Johnson
Re: Johnson Seahorse 20hp (1984)
When you say steam, is the engine over-heating? Can you hold your hand to the block?
rbro79
Hi, thanks for getting back to me.
How can I tell if it's white smoke or steam? Will try and put my hand on the block.
Cheers
Russell
