johnson prop missing plastic ring on prop exaust exit
rickjm1001
Does it matter?
Went fishing this weekend and when I pulled it out of the water I noticed that plastic ring was missing on the prop.
hidef
Re: johnson prop missing plastic ring on prop exaust exit
Not really. It is there to improve prop efficiency of the prop at speed. However a missing ring on a 9.9 or 15 doesn't really matter as they don't go that fast anyways if you have 140 it might make a difference.
wilde1j
... and it's not plastic on the big props.
the machinist
As I understand, those rings were designed to help (especially on smaller motors, 9.9/15) disapate the exhaust when in reverse.
rickjm1001
it's off a 25 hp,
But now that I think about it I wonder if I did loose a bit of hole shot power and top end.
I did seem a little slower, but not by much.
It's also a 3 cylinder.
jjacobs007
Who needs em! plastic ha,not gonna make a differance on that mtr.
boobie
I guess the manufacture of the mtr didn't know what he was doing when he put the ring on the prop.
AEROCOOK
Master Chief Petty Officer
I'd really like to know for sure, I noticed mine is missing too... 1988 110hp Johnson.
mark1961
Ensign
The plastic ones (lexan) are still available for some motors, they are a bugger to fit though.....
The correct name for them is a "converging ring".
rickjm1001
OK what's the downside to not having the ring?
AEROCOOK is also missing it.
mark1961
Ensign
Not much but i found this......
The loss of a converging or exhaust ring from a thru-hub exhaust propeller will mean that the exhaust gases going through the propeller could either escape between the propeller and the gear casing if the converging ring is missing or not be properly deflected if the exhaust ring is missing.
http://www.propellerworld.co.uk/,_what_do_the_measurements_on_m.html
And this.....
http://forums.iboats.com/showthread.php?t=241546&page=1
fmalott
i got a 1980 25hp seahorse i used the same prop with no ring for 15 years made no difference finally chewed up last year found a used prop with ring did not make a difference either so don't worry
BoatingCop
The first time I used my 9.9 Johnson I didn't know there was supposed to be one there and mine was missing. My 14' aluminum boat wouldn't plane at all. I got a new 4 blade thats flared at the end and it does fine. And no, the hub was not slipping. It would just cavitate. If your prop is flared at the end that means its a newer one and that why you're not having the issue
