glnbnz
Thread starter- Joined
- Oct 4, 2011
- 458
Hello,
I am wanting to get a new prop for my boat. I have only owned the boat for about 2 months and got it out into the water 1 time.
1) Performance issue you are trying to correct. I would like to know what would be a good starting place so that I can best pull skiers
2) Current prop manufacturer, model, aluminum or stainless as a minimum. Unsure about the Manufacture or model, but it is aluminum.
3) Current prop diameter and pitch (required). Stamped on the side is 13-3/4 x 15
4) Wide open throttle RPM and speed with an average load (very helpful) Unfortunately the tach is broken. It seems to run 30-35MPH
5) Engine/drive make, model, year, and HP Johnson, 1975, 85HP Outboard
6) Boat make model, year, length and weight Ozark, T-164, 1973, 16ft and not sure about the weight
I am really looking for a good starting place for pulling skiers. I figure that if I can get that accomplished that I should be able to do pretty much anything else I need with the boat.
Thanks in advance.
Thanks in advance.
