I got the motor mounted on solid. Used biggest bolts I could fit through the factory sized holes on the stern brackets. Looks great finally on there. I also mounted up the motor controls. I need to replace the solenoid but the rest of the electrical tests good. Neutral safety switch and all grounds 12 volt test good. Now working on the steering linkage to the motor. The boat has a push pull steering system. Not cables/pulley like was common on this era of motor. I need to fab something up but make it so the linkage will move with the motor when put up for trailering. I can't seem to find a good closeup of this anywhere on my motor type. YouTube and Google didn't show much. The only video with this setup I found doesn't get in close enough. Can anyone posts, send me a picture or diagram of this setup? I was thinking a heim joint setup might work but open to ideas or the correct setup if I can get a picture.
